Hello everyone.
When you reach(if you do) alltitude of 500 meters with your P3S, how do you go up? Do you go at once? Or slowly slowly?
Cause i always had a problem going up, my max was 200 meters, not even. After i was getting weak remote signal and rth.
So today i tried this, went up as much as i could, which was around 160 meters, and after, did a little by little. went slowly 10-15 meters up, and the moment i started to get weak remote signal, i would move the bird, a bit forward or backward, also slowly, until it wouldn't catch green signal again. after it did, i would go slowly again 10-15 meters, until next weak signal alert and so on, until i reached 350 meters, which was my max set in the settings.
1) Is it how you all do, with your standards, adv and pros? Or still something wrong with my Standard.
When i flew away for around 400 meters from me, it lost a signal, very strangely. It went all grey, and connection between remote and bird was lost. The screen was grey. This lasted for like 10-15 seconds, i was panicking, i walked around and signal got renewed.
I have a question, what would happen, if signal wouldn't get renewed?
Cause as i understood, the bird wasn't doing the RTH, eventhough it was in the Failsafe settings. Because after it reconnected, it was still at the same place where it lost signal.
2) So, why does the GREYING Out happen? And how to avoid it?
