Weak gimble magnet?
Im curious if this a thing? After gettig the crazy gimble wiggle, where i needed to take the back cover off and make sure that the post had the flat piece straight across, it seems that, while flying, it will start to get a crooked horizon.
Then ill have to straighten it again. Also, it seems as if the front part, that normally would tear the ribbon when it comes off, has been slidding off with alot more ease then before.
Is there a suggested way to go about this? Its been extremely frustrating.
thanks in advance
Can u upload some photos so we know exactly what and where. If it is the roll ring that goes around the back of the motor, I use red loctite
You can just pull it right off. Seems like I'm missing something, or clearly not doing something right! Aha
that is not good dude. I use red loctite on the shaft end that goes in the hole. Just a touch. Make sure the flat is correct. Let it set for a day before u fly.
Johnboy94
