weak controller signal - won't start at all
I hadn't used my drone for a while and went out yesterday and got all set up and the weak controller warning came on, would not even start the drone. Went home, looked up some info and decided I should update the firmware. That did not help, it took about one hour to update. I charged the battery again, and tried to fly, but the warning is still there. The drone will not even start up. Where do I go from here?
Welcome to the forum!
What color is the light on the remote?
Rod
green and the signal goes from poor to good but no luck with getting it to start up.
Calibrate controller?
Start-up requires full stick deflection.
If that is not 'sent' it won't sense start.
I now have it flying after re-linking it, but I can't see what my camera sees because apparently my phone updated to a version that it doesn't like. I bought a Samsung Tab 1 since I read that it would work, and it doesn't. Not loving my drone today.
just read a comment on another link and problem solved. After updating firmware, re-linking and now turning things on the right order it works. Drone, controller then plug in the tablet. made all the difference.
Thanks for the updates!
Rod
