If flying over greater than 100' water depth, I wonder if you could piggyback a second GetterBack to the first in series so they both activate and provide a longer line.
And are the suits able to come off when I don't want them on? I see on the website that they are also the wet suit so I can fly in rain.
Yes, thats what I was probably going to do anyway. Do you know how they know what happened? Cause it says they don't cover malfunctions. How do they tell what happened?Forget Refresh and insure through State Farm for $60.00 a year full coverage! They cover even fly always!
Good luck
Jim
WA5TEF
State Farm does not cover drones in California.Yes, thats what I was probably going to do anyway. Do you know how they know what happened? Cause it says they don't cover malfunctions. How do they tell what happened?
We designed the Rescue Jacket but it is not Water Activated , you simply fly with the Rescue jacket on while you are flying over the water or testing new flight areas.
This is Rescue jacket holding up the Phantom 4 Pro from sinking in the water, the unit weighs 4.5 ounces.
We have more videos at Phantomrain.org but this will give you an idea what it can do in a landing or crash.
We have also tested out the Aerodynamics in flight and have found that with the exception of long distance records this works extremely well with sensors off and VPS turned off as well.
I assume that this test destroyed the camera? Or...the camera was destroyed BEFORE you conducted the test, yes?
D
