Has anyone done it? My friend pointed me to this video & it seems he has web store that sells the kit.
Reminds me of the lens kit did GoPro
http://youtu.be/xlXoJFM1Blk
Its a flat field Rectilinear lens which gives no fisheye and no need for any distortion resulting from having to previously to correct it in software. It is also about twice the focal length of the standard lens so no need to get physically quite as close to the subject. Image area on the sensor is 10 mega pixel which is still amazingly good.locoworks said:the lens seems to have removed the barrel/fisheye effect, is it edited out of the video or is the lens upgrade the cure??
Like I said FL is twice the stock and therefore FOV is 80 deg compared to 140 deg - or is it 160 deg? It means its safer because you do not have to fly as close to subjects as you would with the stock lens...unless you want to of course .malacca said:It would be nice to see some before/after shots demonstrating the fisheye removal, but more importantly how the FOV is altered.
In this video I took of Common seals the first lot of scenes are with the stock lens. From the misty day scenes onwards are with the 5.4mm lens. Remember this is with tbe gopro Hero 3+ Black edition but the lens is the same as the P2V+ replacement kit.malacca said:It would be nice to see some before/after shots demonstrating the fisheye removal, but more importantly how the FOV is altered.
IrishSights said:In this video I took of Common seals the first lot of scenes are with the stock lens. From the misty day scenes onwards are with the 5.4mm lens. Remember this is with tbe gopro Hero 3+ Black edition but the lens is the same as the P2V+ replacement kit.malacca said:It would be nice to see some before/after shots demonstrating the fisheye removal, but more importantly how the FOV is altered.
Seals of the Ards: http://youtu.be/BxjXr-TFD7A
What app did you edit your video with?IrishSights said:In this video I took of Common seals the first lot of scenes are with the stock lens. From the misty day scenes onwards are with the 5.4mm lens. Remember this is with tbe gopro Hero 3+ Black edition but the lens is the same as the P2V+ replacement kit.malacca said:It would be nice to see some before/after shots demonstrating the fisheye removal, but more importantly how the FOV is altered.
Onezerosix141 said:
