Video feed loss after trying to repair gimble
I was in the process of adding lock tight to he horizontal plane gimble pin. I removed the board with the D sensor and plugged it back in and found no video signal to the app. I checked all the connections and all cables plugging them in and out, all looks to be fine.
Fishing for the issue I read about the wifi module problems. I did find a dent on the top of the wifi module, even though it was working fine prior (to trying to fix the horizontal plane) I replaced the wifi module. Same result, no video feed. I can connect to the wifi and the phantom, receive the data, battery %, sats, sd card. I can start and stop the video but when I try to take a picture it says phantom connection broken, and wifi data time out. Also can not see any of the pictures through the app on the sd card.
Any suggestions? am not sure what else to try. Thanks!
I am running the latest app and firmware on all.
Don carlos
