Upgrade FC40 Camera?
I was wondering if there as a way to upgrade the Stock FC40 camera yet still use the same FC40 holder?
Basically is there another camera that would fit in the FC40 camera holder?
Thanks!
As far as I know, there is not another camera that will attach to the FC40 and still retain the live video feed. I believe you could attach a GoPro with the Phantom 1 mount, but again, you wouldnt get the FPV which is the selling point for the FC40.
There are two different directions for "upgrade". If you want better FPV, you use a video camera and video tx/rx/monitor setup.
If you want higher quality, you typically go for a GoPro. You can go both directions at the same time, and use a GoPro with a video tx/rx/monitor setup.
Only trick for the FC40 is to use a 2.4Ghz (or anything other than 5.8Ghz) frequency setup. The big thumbscrew mount is a standard GoPro mount,
although you'd typically replace it with an anti-vibration bracket.
