Unit not powering on
Discussion in 'Phantom 2 Vision + Discussion' started by wopak, Sep 15, 2014.
  1. wopak
    Hi,
    Need your help with my Phantom 2 Vision+, I resorted to this forums since I cant search any solution on google.
    My Unit wont turn on. :(
    Battery is fully charged (shown when pressed once) but when I power it on, Nothing happens. No lights, No power on sounds.
    Hope someone can help me with this problem.
    thanks
  2. nintendrone64
    Simi Valley, CA
    You are pressing the power button once, and then holding the power button down for several seconds?
  3. wopak
    That is right. press once. then press again and hold it for a couple of minutes.
  4. RIDETOEAT
    Madison Indiana
    Sounds like you are doing it right, all I can think of is to pull the battery and inspect the male plugs that are in there and plug into the battery on insertion. Is it new ??
  5. wopak
    not new, almost 3 months
  6. DrJoe
    If your not a noob, and have successfully powered on the Phantom before.... try this:
    We need to know if its a Phantom problem or a battery problem.
    1. With the battery outside the Phantom, press and hold the power button. 4 lights= 80-100% battery life, 3 lights 80% battery life. How many lights do you get? If none, your battery is toast.
    2. With the battery outside the Phantom, press the power button and press again and hold. Do the lights come on on the battery? If no, your battery is toast. If yes, let's try the Phantom.
    3. Clean the contacts of the Phantom battery connector. Connect the Battery. Power on the battery. If the battery lights up, and stay lit, but your phantom doesn't , you Phantom is the problem. Open it up and check connections/wires. Use a micrometer tester if possible to trace power to the Naza unit.
    Good Luck
  7. Mori55
    NJ-USA
    Press once then press again for a couple os seconds not minutes.
Similar Threads - Unit powering Forum Date
Refurbished Unit Pro/Adv Discussion Yesterday at 7:26 PM
The Old SS United States Photos and Video Yesterday at 8:03 AM
What commercial opportunities are possible for the P3P? Pro/Adv Discussion Jan 8, 2018
Beta Test Opportunity Control (Go, Litchi, etc..) Jan 1, 2018
Employment opportunity General Discussion Dec 4, 2017
