- Joined
- Oct 1, 2015
- Messages
- 72
- Reaction score
- 46
- Age
- 36
I have the Samsung Note 5 and have had zero problems
I have (iPhone 6+, Air 2 and mini 4) and to me the Air is too big. The Mini 4 is much brighter than my old mini 2 and as of today with the new DJI iOS Go APP fixed the lag problems with iOS 9 - I'm really liken my setup!Debating between the iPad Mini 4 and iPad Pro to use with my new P3. I'm thinking the Pro may be a little too big/ heavy, although it would be amazing to fly on a 12.9" screen.
RTH will work fine, on it's own. With the iPads, it's only the Cellular versions that have built in GPS. You already understand this.
You only need a GPS enabled device for Follow Me, also if you want to change your Home Point to the current radio controller location, if you move around. Anyway you can cache your maps from a wifi hot spot, which for you would be the phone, if that works for Apple devices?
RedHotPoker
each time you power up the Phantom's internal gps fires up and quickly notes home position.....it also gives an audible announcement that it has set home point. So being without gps in your tablet won't be an issue for that......however to be able to walk or drive from home point and have it update your new location mid-flight it will need a gps enabled device, but that's only in the case that you plan to leave your home area while in flight..... (not likely but worth noting)How does it know where "home" is if the iPad doesn't have GPS? I guess it can't learn through tethering... do I need to set it somehow? How long does that take to set manually? I'd want it to be quick since I could stand anywhere for the first time and want that to be my home. (Sorry for what may be obvious questions, but without the drone here yet, I can only guess at what the UI might look like.)
(And I doubt I'd use Follow Me... that sounds like a bad idea in this area of the world where everything is hills and trees.)
Had the same problem this weekend. was going between Litchi and DJI Go. Figured out that DJI has gotten set as default app for USB so Litchi got No Signal. Just had to go through settings and clear default. If that is not it, I would suspect a cable problem.I cant connect with my Nexus 7 2013, No Signal. It was working fine suddenly it doesnt connect.
It connects with Note 4 and iphone 6 without a problem. tried different cable same problem with Nexus 7 IIHad the same problem this weekend. was going between Litchi and DJI Go. Figured out that DJI has gotten set as default app for USB so Litchi got No Signal. Just had to go through settings and clear default. If that is not it, I would suspect a cable problem.
