SW 1 , FLIGHT MODE
Hi
I would like to ask is there anyway i can change my flight mode sw1 , from SW UP (GPS) middle (atti)
and down ( failsafe)
to ATT, GPS, FAILSAFE
i already have a list of quads with this kind of set up atti, gps, failsafe
can i change my phantom v2 to this setting
so will not be confuse when using my other quad
also is there anyway we can have a hd preview on ground station
can you solder?
You will probably need to open up the TX and move some wires on the back side of S1.
I don't know about GS
No way to make the change in the assistant software. You would have to do it mechanically on the switch by reversing the atti and GPS wiring. Then test to see if it made connections properly.
Since the DJI equipment lacks the required programmability this mod will require a different type of switch (if one exists) or some other custom interface.
Simply trying to move wires on the existing switch will not work and has potential to cause damage.
The current S1 & 2 switches are SPDT on-off-on with regards to the three positions as you move from top to bottom locations.
Functionally you'll need a switch that provides off-on-on operation.
This cannot be changed by moving wires.
whoops I think he's right.
3 position center off switches.
I forgot these are on off on.
I don't think there is such thing as as an off on on toggle switch.
If you are hell bent on doing this maybe there is something you could do with a tiny relay. Or two.
You could do this with a 2 pole rotary switch but there goes your standardization.
and wouldn't that look just lovely? haha
