Stress crack repair & protective plugs
Hello guys,
Unfortunately, few days before I discovered my first stress crack on my Phantom 4. I will not go into details, how it was created, possibilities etc. I fly my drone once a week, most of the time hand catch, I use the sport mode a lot since this is offered by the machine..
So as you can see from the photo below, the crack is quite big, and I tried to repair it with Gorilla very strong glue. Before repairing, I removed the plastic prop installation protective plug because it was looking like this does stretch the crack more. I applied the glue, left it overnight, and in the morning it was looking like it was stuck for good, I couldn't see the crack moving if i forced it with my bear fingers. But once, I inserted the plastic protective plug back, the crack opened again :(. I will give it one more try, but eventually I will apply the glue again and this time I will not put the plastic cover back.
Do you guys think there will be any issue if I will use the drone without these protective plugs? I will probably remove all 4 so the aircraft is balanced in terms of weight and aerodynamics.
Thank you
What motor is this on?
My first crack looks like it was in the exact same spot.
Good super glue fixed it
Take it apart and fix/glue from the inside then a light layer of glue on the outside.
Not issues on mine after that other than two more in a different spot now.
Haven't through fixing it from the inside. That requires quite a dissembling :)
I might give it a try over the weekend.
Thank you for the advise
