Apologies if this has been discussed before - but I have done a fair bit of searching and cannot find this exact problem.
A brand new P3 Standard battery has been charged successfully once will not charge a 2nd time. When put it in the aircraft and turned on the first light glows green for a few seconds and then dies - the battery is flat....I believe.
When I plug in the charger 1) with the battery off, all the lights come on in sequence 1,2,3,4 + the on button is red and then all go blank - this is then repeated every 5 seconds or so. I have left it on charge for a couple of hours to see if it will sort itself out but it is still flat. 2) with the battery turned on - all the lights come on and the 4th flashes for a while then it returns to the same behaviour as 1) above.
Has anyone else experienced this? or is this just a dud battery? The manual does not cover off anything about this sequence of battery lights and after many hours Googling, I am thinking it could be a warranty job. Any help/suggestion would be gratefully received.
