short circuit
Hi!
Lost my video stream due to what I Think was a short Circuit in the auxiliary Power. Brown/red feeding the AVL58.
Anybody with similar experiance and/or have some sulotion to the problem. Using a Phantom V2, GOPRO, gimbal h33d, AVL58.
Why do you suspect a short?
Do you see damage?
Do you have a volt meter to test with?
You need to look inside the P2 next to the PCB connector for the camera.
There have been several occurrences of this and if it is the same as seen before then it is likely you'll see the damaged part.
did some screwing and find this
. seems like the shor Circuit was on the video Cable:) any suggestions?
That's what I was talking about.
If you look around here you'll see others have had this issue.
The only repair I can suggest is replacement of the board.
There are those here who say they are going to do this or that to repair or workaround the problem but I have not yet read or heard any success stories.
The new board is about $70 USD.
Hi, today I installed the AVL58 transmiter, and in the start, occurs me the same short circuit of your picture.
How did you resolve it?
Is it possible to replace the part?
Thank you.
brianklenhart
