Interesting, thanks.I have a P4P and I lost signal at 500 meters away at 115 metres high and it initiated RTH, looking at the 400 meter fly back it keeps a steady 113 metres altitude all the way back.
Yes, I was kind of hoping for more feedback from others so Ill ask again:. Has anyone been able to positively determine that their P4P does not have the problem? (i.e., you fly out approx 1 mile or more, press RTH, and the unit does not exceed the preset RTH value on the way back?) You will not see the problem on RTH from short distances so the test must be performed at a range of approx. 1 mile or more. Please report only if you have performed the test exactly as described with a P4P, along with your OS and firmware level. It only takes about 10 minutes and any data will be much appreciated.
I am currently working with DJI support on this issue since I (and apparently several others) can reproduce it at will. I have not flown since the latest formware update however and I will be testing again today.
Snowwolf, are you using an Android or iOS device?I have a P4P and I lost signal at 500 meters away at 115 metres high and it initiated RTH, looking at the 400 meter fly back it keeps a steady 113 metres altitude all the way back.
Flew out 6500 feet away. RTH stayed at 200 feet the whole way home. I'm running the current firmwares and on iOS.Yes, I was kind of hoping for more feedback from others so Ill ask again:. Has anyone been able to positively determine that their P4P does not have the problem? (i.e., you fly out approx 1 mile or more, press RTH, and the unit does not exceed the preset RTH value on the way back?) You will not see the problem on RTH from short distances so the test must be performed at a range of approx. 1 mile or more. Please report only if you have performed the test exactly as described with a P4P, along with your OS and firmware level. It only takes about 10 minutes and any data will be much appreciated.
edit: I was mistaken see my new post below! issue confirmed.OK, I think I've figured out why some are seeing the problem and many are not. If you are below the preset RTH altitude at the time that RTH is initiated (which is probably most commonly the case) the aircraft will climb to the preset altitude and return home, just as it should. In fact mine does that too. But... if you are already above the preset RTH altitude when RTH is initiated then the problem seems to occur, as if the unit is trying to climb to RTH altitude but somehow doesn't realize that it is already above due to some software bug, so it climbs continuously. I can repeat both scenarios reliably.
This is not correct behavior of course, if the unit is above RTH altitude it should hold its current altitude on the return home in that case, not increase altitude apparently without limit. But for now at least you can avoid the issue by ensuring that your RTH altitude is set above your planned flight altitude.
If anyone has a chance to test this theory (i.e. set your RTH altitude to maybe 25 or 30 meters and then fly above that altitude and initiate RTH and see what happens.
Boy, now I am confused.I did an RTH at 300 feet yesterday which is 100 feet above my set RTH while 5200 feet out. It stayed at 300 feet the whole way back.
I think the issue is only affecting certain units.Boy, now I am confused.
Possibly, but I fail to see how this could be any kind of hardware problem since the unit flies perfectly in all other flight modes and if there was a hardware problem of this magnitude you would certainly see some other effect. That, and the fact that everything works properly when below preset RTH seems to point pretty clearly to a software issue. I think most likley it is a combination of some causative factors or settings that we haven't figured out yet. I'm convinced that if an 'unaffected' unit duplicated the same settings environment then it would see the problem, but there are so many variables I can't guess what that combination might be.I think the issue is only affecting certain units.
Yep, it's frickin scary. And the hardest part has been convincing people it's realSo I just went outside and tested now. I had RTH set to 180 feet and I was flying at 250 feet. At about 3800 feet out I lost both transmission and image, and it auto initiated RTH. A few seconds later the TX reconnected and I watched and sure enough!!! If you are above RTH set height and you are far enough out, it just CLIMBS. And it seems to climb as fast as it can climb too. It got to almost 500 feet before I hit down on the left stick.
Tested it again, same result. Seems pretty easy to reproduce.Yep, it's frickin scary. And the hardest part has been convincing people it's real
Yes, once you see it you will be able to produce the same result at will. I think it might well affect all P4P units, but just not widely noticed yet since most tend to operate below their RTH preset.Tested it again, same result. Seems pretty easy to reproduce.
Just FYI to all, this moring DJI CS got back to me and reported that their engineers had confirmed the bug. Basically what happens is that sometimes when RTH is initiated above the preset RTH altitude setting and the unit erroneously thinks it sees an obstacle (perhaps confused when it yaws around to point homewards) it rises to avoid the imagined obstacle but instead of stopping after a short distance it continues to climb continuously. The problem should be fixed in the next firmware update.
Can't say, that's only what DJI reported to me. The English wasn't great but I'm pretty sure that's what they were trying to say.I'm almost 100% sure that someone tested it with OA off and it still climbed. Maybe RTH OA was still on
