Looks good - does it affect the flight times much?
Josealb, do you have problems with the added weight on the phantom from carrying the sensors and battery? I have basically the same set up as the one you shared and when I tried landing my drone the first time it plummeted from about 10 feet and crashed. Also during the flight it struggles to hold elevation and will fluctuate about 5 feet up or down. I am guessing it is because the mount sits underneath the drone where the sensors for elevation are but I am just wondering if you or anyone else has experienced anything like this.
Another thing was on both the PIX 4d app and Drone Deploy the drone takes off and goes to the first way point at the set speed but then once it starts flying the path the drone flies extremely slow, like 1 foot per second. Im guessing the problem is the added weight because the drone flies the paths normally without the set up for the sequoia but Im not sure.
Hey there @Leester we had the same problem and designed a 3D printed mount that has worked very well. It's available now at
Parrot Sequoia mount for Phantom 4 and Phantom 4 Pro | ZCopters
@John Locke one of the good things of the Sequoia is you don't need any interface to the Phantom, as long as the camera is powered (which we do with an external battery) the camera uses GPS to trigger pictures and to georeference them
Did you encountered any interference issues?Hey there @Leester we had the same problem and designed a 3D printed mount that has worked very well. It's available now at
