- Joined
- Nov 19, 2016
- Messages
- 15
- Reaction score
- 2
- Age
- 51
Any idea what is the best settings for sensitivity on the remote sticks?
So I can do as smooth as possible moves?
Mine super smooth just in GPS mode,,,,,have seen that somewhere in stick input ....not sure,,,,,,maybe where you calibrate sticksAny idea what is the best settings for sensitivity on the remote sticks?
Here is a good video to watch regarding your question. I set all of my Sensitivity settings at .35 for both standard mode and Sport mode. This makes for some smooth movements, but you have to get used to it, because it is a bit 'gummy' at first.
Thank you for posting this! This is exactly what I needed to fix my rotation sensitivity!
You bet! Just be extra careful at first as responsiveness is a bit muted compared to default settings. I suggest that wide open area that you probably first flew at...
If you like taking things apart, you can install a 20ohm pot with switch linked to the yaw controller and take it down to any rate.
