Scattered view on 4+remote
While I’m flying and not recording, sometimes the screen on my remote gets a scattered look like a television with a bad antenna, I have my WiFi off,, is this a antenna issue? How can I fix this???
You might need to examine your antenna orientation (on the remote) or look into a Windsurfer:
https://smile.amazon.com/TOZO-Parab...357&sr=1-1-catcorr&keywords=phantom+4+antenna
You can also switch back and forth from 2.4 to 5 Ghz and see which performs best.
Here's an idea about orientation. Directly above the transmitter is a dead zone, if the antenna is pointed upwards. If all this fails, just try another phone/table, just to eliminate that.
Here's an idea about orientation. Directly above the transmitter is a dead zone, if the antenna is pointed upwards. If all this fails, just try another phone/table, just to eliminate that.View attachment 99865
Anything will help, I’m wondering if I should just leave my WiFi on??
How do I change from 2.4 to 5 GHz
I found out that mine will change automatically and that the screen will only start getting jumpy when I have reached my maximum distance, does this change when I switch out of the rookie mode? My max distance is about 1100 ft
You may not realize it but you helped a lot... thanks
TimCJWolfe
