and the later fly-away video
The "jello" I put down to the blustery wind pushing the P3S around ...
Nigel
Another Phantom owner (he has Pro) says my videos show I haven't removed transport strips ... I can only find one that did not hold anything. It had an orange tab end to it. It was along one side on bottom face ...
Did you remove the Styrofoam block that is between the gimbal and camera top?
Your "jello" effect isn't likely the wind and you have a very pronounced tilt showing on your videos (Styrofoam block maybe). Or, more than likely you need to do an IMU calibration.
Be sure you do that calibration when the Phantom and battery are completely cooled down and the Phantom is sitting on a perfectly level surface while IMU calibration process is underway.
Even better when the battery and bird are cooled below your outdoor flying temps prior to IMU calibration - otherwise it may take longer than you expect for the unit to warm up prior to flying.
Good luck with your new Phantom - safe flying.
not pins like mine
Looks like it's still there.
Sent from my XT1575 using Tapatalk
It may not be there now, but is certainly there in the picture.
