RTH Altitude Definition
If the Home Location is set at the top of a hill and the drone executes a RTH at the bottom of the hill, is the return altitude determined relative to the Home Location or relative to where the RTH was initiated? This can make a big difference in setting the RTH parameters.
It's relative to the takeoff location -- which should be the home point if you do not reset it again after takeoff.
Reactions: Paul Schulze
Yes. If you fly below the takeoff point, your altitude will change to a negative value.
