Have you balanced the RotorPixel by adjusting the position of the RP base? If the gimbal is twitching, then there are wires touching something or the RP is not balanced properly. I went through this when I first got my RP about a year ago. Here is a link as to how to balance the RP,,,,,especially useful if you add the filter adapter and a filter to the RP.I can't find the area talking about balancing this and calibrated what ? the bird??
SweeeeeetThanks and I saw that and did it but don't help my issue for some reason .
I did the balance thing and also the calibration to it . I have it working perfect as
long as I leave the filter kit off . I only had that on there to have a UV lens over the camera lens to protect it . I have messed with the settings till I have just gave up for now on getting it right with the kit on it
It works great and is balanced good as long as I leave that off and I want to enjoy it awhile before I keep on messing with this thing
Thank You very much to those that have tried to assist me with this and most likely would have worked fine if I hadn't had the weight on the camera and had just asked before I jumped right in but I was just too **** inpatient and had to put it on
Now to try it out some !! Thanks again and sure ...I'll be back in this tread
I also have the lens adapter and filter. I hope I do not have to remove it to work. I would rather return the gimball.Thanks and I saw that and did it but don't help my issue for some reason .
Someone in the same area as me
how did this happen? I havn't had time to fly mine much. First couple of flights after installing the RP gimbal were not very good. The gimbals slow to start and the behavior is not consistent.HELP RPG !! What to do ?
Ya can see what happened in GD so not gonna repeat it here but what should I do ?
Need advise from Keri on this !! Send it back to ya and see just what it will cost to fix ?
View attachment 16707 View attachment 16708 View attachment 16709
That's not wire ya see in motor but trash and the black cover goes right back over but ya can pull it back off . Thing worked great and I loved it for about 5 trips
http://www.phantompilots.com/threads/mia-rip.37903/how did this happen? I havn't had time to fly mine much. First couple of flights after installing the RP gimbal were not very good. The gimbals slow to start and the behavior is not consistent.
What is the tracking telling you ?I ordered my RP about 3 weeks ago still not received it as yet. I've also emailed Keri for an update & the tracking number but like Dirkclod I've had no reply. I was told by email from Keri that it should take about a week to get to the UK (this was when I placed the order)
I've emailed RP 3 times now.....
Now I'm getting worried
That's the point I've not been given a tracking number hence why I emailed Keri asking for it. My bank has confirmed that payment was made 3 weeks ago now I can't get hold of anyone at RP. Don't know what to do next... Helllllllp..What is the tracking telling you ?
