Rookie needs help w P3 Gimbal dance
I was flying my P3 the other day and landed a little hard/fast on a sidewalk. My Gimbal instantly started moving all around and would not stop. It now says Gimbal motor overload and every time I start it up it freaks out. The camera works but it won't stop moving. Any ideas how to fix this?
Thanks,
Steve
Check the Gimbal motor housing you may have bent the outer casing thus causing it to bind which keeps the motor from running freely. You can also check your Gimbal wiring it may be damaged so it will not communicate with the copter correctly. I had this happen to me before and ended up replacing both of the above mentioned items.
Hope this helps?
Justus
