Return To Home Speed
Is there a set speed for the P3 to RTH at? Does it use full throttle or a little less?
I've used RTH a couple of times to test but they have only been short so haven't had time to work out if it used full throttle so to speak.
I remember using the RTH feature on my P2 once when I hadn't noticed the battery running so low so initiated the RTH but it was fighting a head wind on the way back and seemed to be standing still. Panicking about the battery I took control and got it back much faster myself by giving it full throttle.
You can hold 'forward' on the right stick to make it go faster. You have complete control of the bird while its in RTH mode.
Didn't even know that. Thanks! Imagine that the bird is auto-landing (RTH mode) but.. Not exactly where you want. If you turn right, will it continue to go down while you correct its position or will this action interrupt it? I know there's a button to interrupt RTH, but you know..
Yes, but speeding it up will also drain the battery fastero_O
Yes what? Yes it will interrupt it or yes it will keep the RTH? :D
Perhaps .. but not much.
The Phantom goes faster by tilting more - not by having the motors rev harder, which is what makes the Phantom climb higher.
It's better to get your Phantom home earlier by going faster than to have it run out of battery because RTH couldn't punch a headwind.
Reactions: J.James
I don't believe that is correct. Quads tilt for horizontal momentum, sure - but they need to rev harder to gain speed. And they still need to offset the constant 10m/s of gravity at the same time so more power is needed than opposed to just hovering in one position.
Here's instant calculation:
(edit: sorry, correction below!!)
tilt[deg]: power[hovering=1]: y accel: accel/power ratio
0 : 1 : 0 : 0
5 : 1.00382 : 0.0871559 : 0.0868243
10 : 1.01543 : 0.173649 : 0.17101
20 : 1.06418 : 0.342021 : 0.321394
30 : 1.1547 : 0.500001 : 0.433013
45 : 1.41422 : 0.707108 : 0.5
60 : 2.00001 : 0.866027 : 0.433011
89 : 57.3106 : 0.999848 : 0.0174461
Actually "y accel" is horizontal vector of thrust, almost proportional to terminal speed of traveling - drag increases if P3 leans, thus max effective angle will be < 45 deg on real P3. Anyway Phantom is limited to lean <= 30 deg (I remember), then higher speed is more effective by power to travel constant distance.
Reactions: Meta4
Interesting. Where'd you get those calculations from?
At 30 degrees tilt, you'd get 0.5m/s/s acceleration with just 15% more power from the standard hover? So after 60 seconds it will have covered 900 meters and be at a speed of 30m/s?
Yes, you can steer it to a better landing spot during RTH function..
RedHotPoker
Sorry, that's only factor where hovering as 1... but it's almost 10 (9.8) m/sec^2, in case of 30 deg it's 5m/sec^2. And donot forget drag by air... accelertion (force) decides the terminal speed.
Sorry again for correction... I'm so bad at physics. :) Of course, increasing angle of attack, need more power but speed increases (till 90 deg).
Here's correction, with final speed, (final speed / power) by approximated model of drag by P3 body.
description and assumption:
aoa: angle of attack, pow: relative power P3 needs (hovering = 1.0), yacc: horizontal acceleration (gravity = 9.8m/sec^2 = 1), vterm: terminal velocity for horizontal moving. The P3 is modeled as thin paper (cross-section volume increases in proportion of sin(aoa)), no vertical lift/drag concerned. P3 max speed be 16m/sec at 30 degree.
aoa pow yacc vterm vterm/pow
0 1.000 0.000 0.000 0.000
1 1.000 0.017 2.590 2.589
5 1.004 0.087 5.808 5.786
10 1.015 0.176 8.294 8.168
15 1.035 0.268 10.323 9.971
20 1.064 0.364 12.198 11.463
25 1.103 0.466 14.059 12.742
30 1.155 0.577 16.003 13.859
40 1.305 0.839 20.513 15.714
45 1.414 1.000 23.308 16.482
60 2.000 1.732 36.480 18.240
89 57.299 57.290 1122.970 19.599
Anyway velocity/power ratio is better as it leans. Max speed (16m/sec at 30 deg) and half speed (8.3m/sec at 10 deg), battery life differs only 15%, efficiency differs 1.5 times. Result: better max speed RTH.
I calculated by Perl script. Again, I'm not so good in physics... anyone give me advice. :)
  • calcp3speed.perl.txt
This thread reminds me how much I hate physics and math . I'm glad there is people out there that are not only good at it but also enjoy it.
I don't think you can roll. It flies back in a straight line.
