Beat me to it,sorry for the repeatMy guess would be you have it set to “hover”.
Change to “return to home”.
Pull up a chair and your favorite liquid in a glass and go through the app settings. They can be hard to remember where they all hide.
I still do a bit of searching myself.
It's not that your Loss of Signal option was set to Hover, because that would only apply to loss of signal, not initiating RTH.My phantom 4 does not return to home. It ascends to max height and hovers. Im a new owner and dont know what to do when I check firmware versions my aircraft shows version unknown.
As stated; Did you initiate RTH or is this a loss of signal, blank screen, return? (hover)My phantom 4 does not return to home. It ascends to max height and hovers. Im a new owner and dont know what to do when I check firmware versions my aircraft shows version unknown.
So where is this setting,this is only place in my settings where it mentions these options,,I know of 3 sorts of rth,smart rth,loss of signal rth,and manual press on button,,is that right ??if closer than 20mtrs rth will just land or hover ,,correct, even in my home point settings,it say aircraft return to take off point,,,is there more settings ??where ,It's not that your Loss of Signal option was set to Hover, because that would only apply to loss of signal, not initiating RTH.
And it wouldn't make the Phantom climb.
One likely cause might be obstacle avoidance trying to climb over a low, bright sun that it sees as an obstacle.
You need to post flight data to confirm if that was what happened.
Ha yip thanks,,I did see rth in obstacle avoidance about avoiding things on return but did not think that was it,,I know of all these but thought some might be hiding,,,,[correct, even in my home point settings,it say aircraft return to take off point,,,is there more settings ??where ,
[/QUOTE
Adv settings, signal lost, (return-to-home). Tap to select other choices rth, hover, land
I initiated RTH I turned off obstacle avoidance and it works great.As stated; Did you initiate RTH or is this a loss of signal, blank screen, return? (hover)
You have things quite mixed up.did it say when you did the compass home spot is OK ! if not that could be problem home spot never recorded
