How do i remove the damper without breaking the pins?I smacked it into a wall and did some damage to the zenmuse 3d and need to check it or try and fix it?
Don't think you can. Theres been some people who've replaced the pins with small wire ties that are left kind of loose which sounds like a better idea than the pins anyway.
Yep, plastic cable ties do the job perfectly, just leave them a little loose. Their only purpose is to stop the gimbal and camera falling off if the rubber shock-absorbers break free of the mount.
