Removal of phantom2vision plus MotherBoard
I want to fit a new shell to my dinged up P2v+.
Have stripped down to motherboard but now stuck.
One motherboard fixing screw is located under the gold transmitter module.
How do I get at this?
Looks like the tx unit needs removal but no obvious screws? Is it double sided taped to the motherboard and how easy is it to force free? :ugeek:
Thanks
You need to lift the wifi module. Remove the one screw on its bracket first, then apply firm but continuous lifting pressure on that side. The box may not budge for a while, but just keep applying pressure. Eventually, it will start to give. Keep up the slow steady pressure (be very patient) and it will lift off cleanly.
You don't need to remove any wires for this.
