Remote Control
Yesterday was flying with no problems. And today with no reason remote control doesn't turn on. It shows green light for 2 sec, then bleeps and then red light for 1 sec and turns off.. have bought batterys and changed but again the same.. any suggestions ?
Try recalibration of tbe remote control through the RC Assistant and see if that helps.
Make sure your batteries are making good contact with the battery contacts, and verify there is no corrosion on the terminals. If still no go, remove the back of the controller. There is a small reset button on the main circuit board inside. Hold the reset button while powering on the controller. If successful, recalibrate the controller afterwards.
most
