RC Rubber pads sticky stuff
Manchester UK
What are you guys using to stick the rubber pads on the back of the remote, ive tried 3 different double sided tapes and hot glue but they eventually come off.
Reactions: brigerdrones
They are tricky if the original stuff is damaged. And if you use the wrong glue and you need to take the controller apart, what happens then? They should have just left holes in the pads so you could remove the screws without jumping through hoops!
Reactions: Jim Canada
Try a good quality contact cement. When done right (read the instructions....twice), the stuff will hold just about anything and still allow parts to be separated, with some force (will not eat into the plastic).
