RC ribbon repair
Is there anyway to reattach the main board ribbon cable as seen in the picture?
You'll need to remove rear cover plate , unattach ribbon from that point ( opposite end from picture ), then FIRST attach ribbon to RC mainboard, feed other end through Rx rear plate, then attach ribbon there replace cover plate!
J Dot
:cool:
Wanted to add if you have never done this, the plug the ribbon goes into has a small black tab you must flip up, put cable in, then lock it down ( flip it back down )
Be aware though, that if it was pulled out of the connector without flipping up the latch, there could be damage to the connector
Maxxuav.com has a good video on how to install new antenna cables in a rc, the video will show you how they are placed and Jake explains in detail how to secure the ribbon in the connectors. Be very gentle, take your time makanice.
irish_phantom
