Range
Just purchased a used but like new Phantom 3 standard. I am getting around 1400-1500 feet in distance before I lose signal over a populated area. Is this about normal.
Even In populated areas there are a lot of variables. In the nearby town, I do much better then that. If you are not in the USA that might be OK. Can’t help you much more then that with the information you gave. Try different locations to get a better synopsis of things.
That's not to bad ,,I'm same boat with mine but probly less than you and I using cheap mod at moment,,when new I be lucky to get 500ft away before losing signal with some rth during that period,,it is bit better now I might get 1km if I'm lucky,,but to keep this p3s on a leash in case it packs a sad,,,,some go for great distance and some just don't want to know,,luck of the draw if you get a good one,,these silly issues made me get the p4,,that made the p3 back in the box,,.the joys of wifi...
Reactions: MotorCycle-Man
intertronixlabel
