quick mount release for gopro
Discussion in 'Phantom 2 Discussion' started by coolhand, Jun 11, 2014.
  1. coolhand
    Atlanta GA
    Has anyone come up with a more efficient way to mount the gopro to the gimbal?
    seems like some kind of quick release and quick clamp on would be way better than tediously tightening and un tightening those two tiny hex screws. It would make downloading, charging, changing parameters and using gopro for other things
    a lot easier.
  2. QYV
    QYV
    NYC
    this 3d printed item on Shapeways has been mentioned in threads recently.
    While you're there look up the "zenclip" it's a bracket for holding the entire gopro assembly in place when the Phantom isn't powered so it doesn't flop all around
  3. grahamgee
    While I agree this CAN be tedious,
    I've barely removed my gopro from my phantom ever since I put it there to begin with.
    The GoPro is easily charged while it's in the gimbal and the SD card is removable, it's actually less hassle for me to leave it in than it is to take it out.
    Maybe check out a MicroSD > SD adapter if you didn't receive one with the SD card you bought.
    Those ZenClips look liek a great idea, definitely need to get myself one of those.
  4. Lenny7118
    I have seen people using a "Hair Rubber Band" the kind women use to put their hair in a pony tail. It's very secure and easy on easy off. I'm going to start using one once the Compass fix ever gets released.
    I bought that ZenClip it's very good , keeps the gimbal in place . I think having the gimbal flop around while not in use is a recipe for trouble. Just my opinion
  5. nzvideoguys
    Christchurch, New Zealand
    I've been using a rubber band to hold the GoPro in place for weeks now. If you feel safer, you could use two, just in case one breaks. Haven't had any problems so far.
    Actually, yesterday I took it out for a test flight, and I'd forgot to put a rubber band on, as I'd taken the GoPro off for another job. I flew around for 30mins and only realised when I got back home. Luckily the GoPro attaches to the gimbal quite firmly, otherwise, I'd be out trolling around in the long grass...
  6. ianwood
    ianwood Taco Wrangler
    Lost Angeles
    My GoPro lives on the gimbal and never gets removed.
  7. coolhand
    Atlanta GA
    thanks for the 3d link QYV,,, ordered yesterday... the 3d technology is amazing and it certainly has arrived.
  8. Ejazzle
    if you could let us know how that 3d printed clip works that would be greatly appreciated!
    I would like a much faster on/off for the gopro as well
  9. QYV
    QYV
    NYC
    may I suggest you follow the link and look at the pictures... it's fairly obvious and a lot easier to just see than to try to explain
  10. Ejazzle
    I should have been more clear. I see how it "works" but want to know how well it works.
  11. QYV
    QYV
    NYC
    ah yes hehe. I would say you can supplement the bracket with a rubber band or 2 until you're confident with it. I can say the quality of materials is fine, I don't feel like they're in any danger of breaking... unless I crash of course but that's on me
  12. MrC
    MrC
    Surrey. UK
    What about the canbus connector on the leg? Do you have to move this to use the zenclip?
  13. Navman
    I have the Shapeways retainer to keep the GoPro in, works great. In a crash it may be better to separate camera from P2.
    Flying over water, I use the one that comes with P2 so camera and machine don't separate.
Similar Threads - quick mount release Forum Date
DBSMod: Quick Release DBS Mounting Adapter for Phantom 3 and 4 Classifieds May 18, 2016
Can you fit the quick release prop guard peice that is mounted on the drone in a hard shell backpack Pro/Adv Discussion Jan 22, 2016
Quick Release gimbal mount Photos and Video Dec 15, 2013
Cheap and quick solution for mounting Galaxy Tab Pro 12.2 General Discussion Aug 10, 2016
A quick jaunt around Papago Mountain Photos and Video Aug 10, 2016
