- Joined
- Oct 15, 2017
- Messages
- 125
- Reaction score
- 43
- Age
- 44
After my 2 1/2 year old Phantom 4 Advanced developed a couple of stress cracks on the lower shell, I decided to attempt replacement myself. There are some very detailed videos on YouTube, which so far has made this project not terribly difficult. One thing I did not expect, however, is that the landing gear replacement would be the hardest part. The cavity in the gear that holds the compass PC board was full of some kind of silicon filler, and this had to be removed to get at the hex screws holding the gear to the old shell. I also found that I had to remove the tiny connector for the compass wiring harness to get the gear free from the old shell. Every YouTube video I've watched glosses over the landing gear replacement, while spending long minutes showing you in excruciating detail the removal of each and every hex screw on the bird.
So, a few questions:
- What purpose does that silicon filler serve? Do I need to replace it, and if so, what do I use?
- For the connector on the compass PC boards inside the gear legs, is it possible to put this in backwards? It seems that I've pushed it in firmly, and I'd hope it wouldn't be possible to install it the wrong way.
- In the event I screw something up on the landing gear, will a Phantom 4 Pro replacement landing gear set work on the Phantom 4 Advanced? I saw a P4P gear on Amazon that stated it's not suitable for a P4A. Not sure why that would be, although the P4P does support two channels vs. one on the P4A.
- Is there any way to be reasonably sure I've gotten that compass wiring connector back in correctly before putting the drone back together? Getting the shell apart is not a task I want to have to do twice; it was a bit of work.
If I've messed up anything in this shell replacement project, it will have been the landing gear replacement, so I'd like to head off problems before reassembly.
Thanks for any info y'all can give me on this.
John
John
