Prop spin
P3S had a crash landing. I repaired but now notice while spinning the props by hand that one of the four does not turn as freely. While the others make a turn and a half or so, the last turns only a quarter to half. The bird seems to fly OK though. Should I replace the motor?
Is there any roughness? Can you feel any end float or axial play (compare to others for reference)? Does it run hotter than the others? Any new unusual sound? Reduced flight time? If no than all is probably good.
Reactions: Mark The Droner
No roughness or excess play. Don't know about temperature, will Go app tell me that? If so will take another test flight and check. I haven't flown a full battery yet to know if there is reduced time. Thanks for your response.
intertronixlabel
