- Joined
- Jan 19, 2017
- Messages
- 94
- Reaction score
- 12
- Age
- 28
What kind of props to you guys recommend for replacement other than the original DJI ones? Just curious if there are any better ones out there in the market!
I have yet to see 3rd party props that work better than OEM DJI props. If you want to use props that are guaranteed to work well, then stick with OEM DJI props.Just curious if there are any better ones out there in the market!
I invested in a prop balancer for a quieter ride. The DJI props come fairly well balanced from the factory but a little fine tuning reduced the high-pitch shrill I was hearing.Okay I was just wondering if maybe they made one that has same performance but slightly quieter.
My pleasure to connect you: Tru-Spin Prop BalancerDo you have a link to the prop balancer?
The Du-Bro model that comes with the correct prop balancing rod for the P3 is available here on Amazon.Do you have a link to the prop balancer?
The Speedy TM prop balancer works well too. I like this prop balancer better since it doesn't come with a bunch of pieces that need to be assembled (like the above Du-Bro prop balancer).
This guy spins them tight.....Im my book that's wrong....He sure should snug them down and use the Dji prop tightener took and run them tight and use the Dji tool to slightly "snug" THEM TIGHT ! After all.......IF you lose a prop in flight ...that quad will fall from the sky....when you decelerate the motors / props the props are subject to >"reversed"< aerodynamic forces that loosen them....! Correct me If i'm wrong !
I spin the props on until they stop freely spinning. Then, I hold the motor with one hand and turn the prop 1/8 - 1/4 a turn with the other hand.This guy spins them tight.....Im my book that's wrong....He sure should snug them down and use the Dji prop tightener took
This guy spins them tight.....Im my book that's wrong....He sure should snug them down and use the Dji prop tightener took and run them tight and use the Dji tool to slightly "snug" THEM TIGHT ! ... Correct me If i'm wrong !
Mark...... Then its pretty misleading then in many ways..especially the drill bit cleaning up the threads (metal) it should say This is Only recommended for the P2 series type props and like you typed....You would Not do it any way !..ThanksThe video above, which I remember from 3 summers ago, was posted in 2014 in the metal hub P2 series days. Spinning on the props was recommended by DJI back then...
Not recommended and not a good idea with the more modern composite hubs or the P3 series with the braking action. In fact, I wouldn't do it anyway, even on a P2 with metal hubs. I would snug 'em up.
Mark....I like your reply and Not the video at 10:50 LOL.....Spin em down tight and Gooooooooooooo f l y LOLYeah - I would not do it the way this guy wants us to (go to 10:50)!
