Problem with imaging after update
Went to fly this morning and was given a message to update the aircraft firmware. Update went fine but when I went to fly the images on my iPad had black lines across any flat surface. Ended the flight, shut everything down, tried to fly again using Litchi and had zero problems. The image was crystal clear.
Anyone else having this problem? All software in both aircraft and iPad are up to date.
Sounds like you have your over exposure display turned on in the camera settings. Shut it off and you should be good to go.
Can be update error
I have iPhone5s where had the same issue but came around 1week after firmware update
and iPhone8+ where no problems at all.
How I fixed:
1) I make much more space in iCloud storage
2) I deleted all rubbish apps
3) Update iPhone5s IOS
4) connect ONLY aircraft to iPhone5s
5) on the main screen GO4 APP hold 3 bars for 10s and really
6) screen with updates will show up
7) refresh update
8) after do it the with controller but don’t connect aircraft with controller
It helped me and I can use iPhone5s again
