Erroneous007 said:SlackerATX said:- Plug-N-Play - No soldering, no disassembly of the phantom frame
Update the gimbal gains in DJI assistant software
You've got to essentially turn off the gimbal controller built into the phantom so it's managed by the new Basecam controller by setting the tilt gain to 0. You also have to adjust the center point and range of the tilt control and slow down the speed of the tilt. Here is an exampled with a good starting point.
Load the default profile onto the controller
Thanks Slacker for all of the information! Regarding the Servo Travel Limits above. I installed the 7th channel lever, which worked, but I noticed that the sensitivity was not very good. If you go into Simple BGC GUI under the RC tab, the Taco profile sets the Pitch Min and Max angles at -35 and 180. If you change those to 0 and 90 and then go to the RC assistant and change the pitch t0 1000, -100, -900 that sets the gimbal up to turn 90 degrees (horizontal to straight down and give a lot more sensitive control with the lever. You might have to adjust to slightly difference numbers, but it gives you a larger range and smaller increments with each slight move of the lever. (I also set LPF to zero to reduce lag and speed to 30 to increase the rotational speed and and in the R assistant changed the manual pitch speed to 40. But those can be adjusted to individual taste.) I should mention that I am still using the velcro mount. My other mount is on order.
thanks for posting this..definitely helped with the sensitivity!
