I wish I could tell you but idk. I bought it when it first came out and it hasn't been updated since, if that tells you anythingDo you know which firmware is currently installed on your remote controller?
Thanks for that info. I'll try that tomorrow and get back to youI'm assuming you are using a firmware version older than 1.3.2 on your remote controller since it hasn't been updated for a long time. If that's the case, then it makes sense that DJI GO would not offer to upgrade it since it must be upgraded via a memory card.
Download the 1.3.2 BIN file here and install it on your remote controller by following the instructions here. If that works, then you should be able to upgrade the remote controller to the latest firmware version using DJI GO.
That's the problem. The RC likely needs to be updated via a memory card. After that point, newer updates can be installed from DJI GO.How is he going to update the RC from the app if the app doesn't connect to the RC?
We'll know soon. It's the first logical step to try considering the above information.Yes, but only IF the app and RC will connect after the update via memory card.
Did you remove everything from the memory card and just put the BIN file in the root of the memory card? How did you connect the memory card to your remote controller?When I put the file on the memory card and try to upgrade my RC it just doesn't do anything.
Some phones do this. There is no way to prevent it from happening.My phone constantly just charges when I plug it into the rc. Even when I change it to PTP and reboot the rc it still just goes to charging.
Hi might need re enter password on wifi again to conectI have a phantom 3. I haven't flown it for over a year and I updated the firmware and it won't work on my phone. It wouldnt update the controller though. Anyone know what I'm doing wrong?
Mayby controler not need update,,That's what I'm using. Could it be because my controller isn't updated? When I updated aircraft I used latest update even though there was one in the middle of the originating update and the one I installed. I can't update controller from my app because it won't do anything
Just have to say aswell when mine updates firmware i thought info went to droneYes I did and how do I do that? The controller hasn't been updated for 2 years or so
