Please, any thougths: Litchi WP mission upload too often ends with "Timeout" error...
Latvia, EU
Hi all!
Recently, I have problems to start Litchi WP missions. And, no - not a particular one, but in general.
Regardless I start on earth on in hover, switch the RC to F mode right before trying to upload mission to AC, or earlier, the usual loading progress window rarely completes - sometimes stops at 18%, sometimes - more, but, anyway it's frustrating (usually, I give up after 2-3 times und just fly manually)
Hardware: P3A (never crashed), iPad pro 9,7", RC with windsurfers (ok, I rarely fly far away, but have no connection or video downlink problems to 2 km range in LOS).
Actual Litchi and iOS versions, FW too.
No problems with AC or other equipment otherwise.
Tried to reinstall Litchi - no results.
Do I need to recalibrate IMU/reinstall AC FW , or anything like that?
Idon't think it happend due the interferrence - I face this problem in different flight locations.
-Any similar experience/fixes in mind? Thanks, M
If you can fly manually with no problems, there isn't likey anything wrong with your hardware or FW. I would try without the windsurfers! In general, I like to make sure things work in stock configuration before doing any mods. It's probably a reach, but the narrower beam formed by the WSs might cause some signal issues when in close.
Reactions: Mix_
Thanks for idea, Richard, I'll try it out!
