Planning missions/flights in live time using Litchi
Northwest USA
Planning missions either on tablet or phone can be fun. Planning missions at home on desktop pc is good for most missions. But Google earth can't see everything for you, Power lines, new or trees that have grown taller. Mabey you need a tightly flown path. Planning in live time is perfect using Litchi. With a hovering Phantom, maximize the map. Fly drone to a point you like and the height you want, pointed in the direction you need. Touch the drone icon on map. Fly to the next point you want and do the same. You are planning a mission as you go along. Save it with all settings relevant to your needs. Tight paths usually need a slow speed. Once you test paths out, you can fly backwards through it giving the footage a exellent view!
Here are my Videos showing this method:
