Didn’t work for me.I saw and have ordered the connector from Amazon. Thanks.
This is strange. It worked for me and for some doesn't work. I used the Syntech connector along with the DJI USB C cable that came along with my Mini 3 Pro.Didn’t work for me.
Picture of the cable you used please.This is strange. It worked for me and for some doesn't work. I used the Syntech connector along with the DJI USB C cable that came along with my Mini 3 Pro.
Let me check with the other USB C cables I have and shall let you know.The only cable I have is an Apple product and it’s a no go.
I did find on DJI website this one, but of course they are out of stock.
Any suggestions?
I checked connecting several USB C data cables with the Syntech connector to GL 300F to my P4P V1. All cables could connect the RC to iPad Mini 6. The USB C charging cable that came with the iPad Mini 6 would't connect at first but after several attempt and connecting/ disconnecting the Syntech connector/ cable it could connect. Also try changing the 3 connectors. FYI I am attaching the App & firmware versions on my P4PV1.The only cable I have is an Apple product and it’s a no go.
Any suggestions?
Apple is about to make your iPad more useful than everThe only cable I have is an Apple product and it’s a no go.
Any suggestions?
Keep me posted if you decide to the get the Orca Wet Suit and I will be glad to include the Rescue Jacket as well for you.Haha, Orca style, that one is good.
An excellent piece of pop art. I'd like to order one!
The downside black-white-silver combination is fantastic.
Although I was able to connect the iPad Mini 6 to the P4PV1 RC indoors, I find the connection very unreliable when I tried to fly the AC with the Syntech Connector. The iPad keeps connecting and disconnecting with weak image transmission signal warning. I am attaching a screen shot of the issue.The only cable I have is an Apple product and it’s a no go.
Any suggestions?
I do not have the V2. But I understand V2 has no issue connecting to the USBC of iPad Mini6.So the V1 has this disconnect issue when using this connector?
Same with a V2?
With this Syntech connector, correct?I do not have the V2. But I understand V2 has no issue connecting to the USBC of iPad Mini6.
