Phantom2 vision w/o gimcal false...
Dear all,
my phantom start up no problem.
and increase throttle without propeller, the all motors spin good.
But, when increase throttle with propeller , the 1st motor will stop.
when increase throttle one more, the quad flip.
Plese help me, how to check and fix with many thanks.
( Please attached link as video)
WIN_20181230_13_57_57_Pro.mp4
video-1546154251.mp4
Thanks and Best regards,
Reed Noel.
Sounds like a faulty esc, I had one fail on mine. Easy to replace, but last time I did one for a friend, and found it hard to source a new one. The vision 2 is getting old now.
Dear @Jayfdee,
Thanks for your support.
I had some FET of esc phantom2, is this false on FET or firmware ?
Rgs,
Reed.
Field Effect Transistor? I have no idea how the esc works.
I doubt a fault due to firmware.
A new esc should be quite cheap, you need to do a bit of soldering, but not hard, it would be my first shot. They do fail quite often.
Have you opened it recently???
If you have, its very highly like the m1-m4 plug on the Naza board is installed upside down.
P2V+ flipping after repair
