Phantom Controller Battery Charging Problem Solved
New Zealand
I found a solution to this old problem.
Credit to goneredcar1 for his detailed explanation & battery replacement video on youtube
The charging board appears to be the culprit in many instances of charging failures
The cells were at 4.1v but wouldn't charge. I separated the cells by cutting carefully through the double sided tape between them, removed all the surface mounted components, then soldered the wires on to the top of the board. Controller now charges correctly
20170902_180252_resized-jpg.87711
20170902_180301_resized-jpg.87712
20170902_180524_resized-jpg.87713
20170902_180547_resized-jpg.87714
20170902_180614_resized-jpg.87715
20170902_181040_resized-jpg.87716
Yup... it seems the culprit is always that little board failing, while the batteries are A-OK .
i have this problem has anyone found a battery replacement yet or is there a vid for yr post
