Phantom 4 Pro - Glitchyness in footage, Weak Image Transmission problems
All transmission problems I've had were caused cable issues. Last two drones I've had apart had cake for thermal paste and bad bluing on the heat sink. Same with controllers, one I have was getting hot fast. Paste is well past its useful life. Better paste available too.
Reactions: Droneted and RodPad
Wow some good info here.
I got this clip which I would call Jello effect. P3A Litchi mission.
I had some others that where really bad.
I'm with both of you. :) :rolleyes:👌
I think a couple more vids would help.
Looked at the first one twice today, there is something different, not like Jello.
Its like a person stuttering.
I like to think of funny *hit, can a comedian actual stutter on purpose?
Rod ..
Hello all,
I have recently encountered glitchy footage on my phantom 4 pro. Has ran great for years. All firmware is latest except for the remote (no way to download the new one on DJI's website, remote doesn't work/connect with DJI assistant). I have an entire shoot with this issue. On site I figured it was just an issue with the remote and interference. However, when I got home I saw that its in the footage on the SD card, which means there's an issue with the camera or software/firmware. SD works on numerous other cameras so it is not that. Tried resetting camera settings, all calibrations.
Anyone have a similar experience with this? Thank you in advance. DJI support does not help, they still think I have the P4P+, when I just have the regular P4P.
If I didn't know any better, I would say that the sensor is loose or there is some other loose component or bad ribbon cable. You didn't mention any hard landings. Has the P4P been jostled in any way, shape or form?
D
If you take a good look at the footage, the image at the top seems very stable. As you view from the top, through the center to the bottom, the problem looks more and more intense. I don't think it's a mechanical problem, otherwise the entire frame would be jittery. I know there have been suggestions of the gimbal, but I don't think it's the problem. Sure would be nice if you had some spare parts to swap out. Jim [email protected]
Digitdrew
