Phantom 4 landing gear replace
Hi
I need to replace my Phantom 4 landing gear, i already bought the part.
I searched the web and Youtube and history on this site and dont find video or manual that can help me ,
Can somone please upload maybe pic with manual or have video in the subject .
Thanks .
Alon
Alonh,
Just dive into it. Not a big deal once you're in it. I've replaced shell on my P4 once and landing gear twice.
You have to pull camera and gimbal off slightly to replace landing gear. That silver brace with 2 Phillips head screws removed to get to the wires that connect landing gear to main.
It's not a big deal. Just be patient and kind.
There is option to replace only the leg of the landing gear and not touch the cables inside ?
The problem is one of my leg broke
Maybe there ia shortcut ? :|
Thank you very much
Finally , a "guide" i can work with
So i pull the plastic cover from the legs
And there is black conecctor ,
Need to unplug the cable from the shell
According to the pic there is like 3 places with "leg cabels"
After i unpleg it
I plug the new legs in the same order
And close the little plastic cover.
All of this without "play" with the cables or unscrew the gimbal
This is correct ?
How do you put back the tabs in the landing gear without breaking them. They are sticking out a little. Can't snap them back in completely.
cid:4BEC7F33-AC12-4CA9-A140-A7BEAE1A70CF@home
Be careful when you press the black connector back down because it will break if you're not careful! I know I had one to break with me while I was doing my shell replacement.
How do you put back the tabs in the landing gear without breaking them. They are sticking out a little. Can't snap them back in completely. Thanks
Lift up on them and push in. You'll notice that there's a little tab on there that you have to mate into the very small hole.
