Phantom 4 - Gimbal Issue, no pitch!
Hey All,
This is starting to drive me crazy. Any help would be greatly appreciated.
When powering on the drone, the gimbal goes through its normal calibration phase, moving from side to side and up and down, then centres. However, once this is completed I can’t seem to get the gimbal to manually pitch (move up and down) only move side to side with the left wheel. The right wheel doesn't seem to do anything at the moment.
I believe that the yaw/pitch was set up as a function under c1 and c2 button. This doesn't seem to be an option for me...
Gimbal Auto calibration, the gimbal moves up and down during the calibration but doesn’t move up and down at all
Camera forward/down - I can toggle a setting for C1 to move the camera down to -90-degree position. This works fine so I assume there is no issue with the motor.
Try going into your camera settings in the app and reset camera settings. This should put the gimbal back to factory settings. Also, go into the controller settings and reset them. It can't hurt to start over, then customize if you really want to.
