Phantom 4 charge hub - multiple batteries at same time
I ordered the Black Box from Amazon but fullfilled by the Tanner Group. It works as advertised and cosyt $48.00 plus $7.00 shipping. Less expensive than from Amazon Prime. I'm charging the remote and one battery even as I type. Charged two batteries after two flights this morning.
$48.00
Reactions: GadgetGuy
I cannot see any firmware download for the phantom 4 battery hub on the DJI site.. Could somebody send me a direct link to the download please.
Thank you
DJI has not released firmware for it yet. Once available, you'll be able to download it from the P4 downloads page.
Unfortunately, the black 4 in 1 BTG charger also won't top off a P4 battery at 97% remaining, just like the DJI P4 charger. Must be a function of the programming in the Smart battery chip on the P4 battery. Still need to run it down to 95%, in order to top it off to 100%.
With my P4, 3% equates to about 60 seconds of flying.. So 97% wouldn't necessarily be a big issue for me.. May be just fly it a minute longer than you would normally to compensate (if possible of course!)
That's about right. However, I assume you mean a minute shorter than I normally would at 100%. The problem is that by the time the 97% battery is turned on and finally ready to fly, it's now down to 95%, after the IMU has warmed up, and the Home Point has been set. I fly with two external 2800 mAh batteries, which deliver up to a 30 minute flight time, so every minute lost on a 12 mile round trip flight is either a prime minute of photography/videography at my chosen remote location, or an extra margin of safety on the return flight, should I encounter a strong headwind on the return, or have lingered too long. On the P3, the battery can ALWAYS be topped off to 100%, even if you topped it off the night before. On the P4, unless it is already down to 95%, you CANNOT top off the battery, even though the instructions state to never fly without a fully charged battery. It's annoying and could potentially lead to a crash or water landing, where the bird would have otherwise have made it all the way home. Now I have to manually discharge each of my batteries to 95%, just so I can then top them off to 100% before flying. This takes at least a half hour with three internal batteries.
I have the $60 one and it works fantastic! Will charge three batteries in about an hour, the transmitter usually takes about 2 hours to get to 100% if it is below 50%, two lights or less.
I wanted a hub charger but didn't want to pay DJI's price. The chargers that charge a bunch of batteries at once freak me out a little as charging even a single P4 battery draws 100W from the wall @ 110V. Are the parallel multi-chargers really able to draw & step down 300W safely? Maybe...
I found a "Smatree" brand hub charger on Amazon that charges one battery at a time like the DJI one does, but only costs $25. I wasn't sure what to expect but it feels surprisingly well made for the price and charges the batteries just fine, one at a time. It draws the same power from the wall as charging a single battery does, and works with the DJI power supply that came with my P4.
300 watts at 110 volts draws only 2.7 amps.
My only concern about a non DJI charger would be the regulators in the chargers being a good enough quality to not damage the batteries.
i have the black one and love the fact i can charge all 3 batteries and remote at the same time and cut charging time in half ....been using mine since last July 2016 with not one issue...nice it has a fan to keep it cool, unlike the stock charger unit that comes with the P4 , mine used to get hot only doing 1 battery = no thank you, when there is the black one out there that does 3 times the work in half the time...no brainer to me
Yeah, there's always a risk I suppose, and just because the hub I bought charges only one battery at a time doesn't mean it will necessarily be safe. I do like that it uses the DJI charger though. I don't have enough time to fly that I am charging all the time (wish I had that problem!) so this works okay for me.
MS60
