Phantom 3 SE
For accessory buying purposes..
Is the camera on the Phantom 3 SE the same size as the camera on the Phantom 3 Professional? Size wise? I am trying to order filters and I’m not sure which size will fit. Most accessories aren’t labeled as compatible with the SE.
The P3SE does not have a removable (screw on/off) UV filter as does the P3A, P3P and the P34K, so if you get ND filters you should look at the slip (push) on type like those used with a P3S. Try to avoid filters that are too heavy. Click here for an example of a slip on set that would also work with a P3SE. Click here for a list of others that will work. Good luck!
Reactions: With The Birds
Thanks so much for the reply. I was out and about and I was going to and grab a polarizer from Best Buy but it turns out it wouldn’t have worked for my drone. So you saved me a little trouble. I haven’t used it yet or even gotten it out of the box so I wasn’t sure.
Johnboy94
