Phantom 3 se litchi
I just bought Litchi for Android directly from Google Play, version 4.10.0.g. I tried in 5 different android devices and runs in all of them. Video feed is fine, and AC data seems ok (battery, etc). I got GPS signal too, and the advanced flying modes seem to work ok also in the P3SE.
I have not flown it yet, but I have no reason yet to discard the App.
Just use the modded app and use FCC mode in the EU.
What moded app?
  • 3.1.8 does not shows maps anymore
  • 3.1.11 does not shows maps anymore
  • .1.18 does not shows maps anymore either
  • 3.1.34 has the WLAN continuous message.
  • 3.1.46 has the WLAN continuous message.
Which one will you use for FCC in Europe?
Thanks
3.1.46 is the latest I just installed it but due to bad weather not flown with it. I used 3.1.18 and that worked. Try 3.1.46 and once installed log in to the drone wifi and check under the 2.4ghz band you should see 1-11 channels I believe.
if it is the same as with the modded app you should only see 1-11 wifi channels.
Yep gotcha. Unfortunately i'm stuck in CE mode when using Litchi with my P3SE (Xiaomi MiA2 Andriod).
The modded DJI Go apps work well providing FCC with channels 1 to 11, was hoping I could get Litchi to do the same.
I have tried the Fake GPS app method, spoofing a location to the US, but Litchi still gives me channels 13 to 20.
Not sure what else to try?
P3SE on latest v1.5.40
Litchi on latest v4.10.0-g
Just of note, when i use fake GPS, the google map in Litchi doesn't display (grey area only).
Hi folks,
I had beautiful flights today with my P3SE and litchi.
I will say it is worth the money. DJIGO does not come even close to this app.
The waypoints mode is just incredible.
just for you to know...
Hi folks,
Yes, Litchi is a good choice. I fly from the start with an iPad Mini 3 and with Litchi. Meanwhile I have learned not to update especially. My P3SE is stable without any problems.
hcashmore11
