Phantom 3 SE centerboard replacement
Hi everyone, recently I had an ESC problem with my P3SE so I bought a new centerboard in order to replace the old one but i noticed that the two codes on the top of the new one are different from the ones on the other; is it a problem? should I replace it anyway or you think that it may cause problems?
Alle just what do you mean By "Codes"......it might be a very good idea to take a picture of the codes on both main boards and then post them here on your thread and wait for a proper answer...!
The second one si the new motherboard
They both look like SE boards from what is depicted in the photos, no shielding cover and absence of SMD components ordinarily fitted to the P3S boards. Wouldn’t be a surprise to lean numbers change during production. Check with the supplier to be 100% and ask for an assurance you can return it if it’s the wrong part.
Reactions: MotorCycle-Man
Ok, thank you so much for your answers
Usachman
