Phantom 3 Pro - Small crash, re assembled camera and now problem
I've had a small accident with one of my phantom 3's whereby I clipped a branch from 2m above ground, it fell onto the grass and the camera came off. I then refitted it back on, thought it was ok and now it's doing this (refer to vid) whereby it will operate ok for 10 seconds and then it will drop the camera and I won't have any operation of it. Anyone had a similar problem?
Check the ribbon cable and even the other gimbal /camera connections.
Acts like the pitch motor loses power or input.
All that happens when you start the bird with the RC already on?
Thanks Air Ontario.. All the basic connections that I can get to look fine. I will take the gimbal off and reconnect though all the connections as a process of elimination. Yes, this all happens when the RC is on and/or off. Thanks again
Check the ribbon cable well, you may have to take 2 screws out of the rounded ribbon cable guard. Also look closely at the wiring where it connects to the actual connector. And of course the other 3 connectors(for a wire pulled loose yet still inside the connector(the multi grey wired ones)
Also sounds like it is reading the Micro SD card?? Do you have any FW files on the card? Light should go solid green on front.. Maybe a different SD card with (or without) current fw (or the one you are currently on?)..
^^^^^^This
Format the SD card and try again. Personally, I would check the firmware is current - and more importantly, directly downloaded, extracted and the FW update is copied to a fresh format card. It it persists and you don't get a solid green, you may have to contact DJI.
Thank you again. All the connections look fine. I swapped the gimbal on my other PH3 for this one and it works ok.
I've been to two repairman since I posted this and both are telling me that I require a new gimbal as it is a firmware gliche in the gimbal that only DJI repair. Even certified DJI repairs here in Australia don't have access to do it. Bizarre. I do trust one of the repairman so I'm sure he isn't taking me for a ride. I think I'm just going to keep it as parts as I don't want to have to spend another $500 for another gimbal
^^^^^^This
Thanks SteveAikens. All the firmware updates have been looked at and it doesn't look to be the issue. Apparently it is a gimbal firmware gliche that only DJI can fix. My bird is out of warranty so I can't return it to them for repairs. See my response to Ontario above as to what the specialists had to say.
DJI had complete gimbal/ camera for $389 usd to your door
B&H in NYC has it as well.. Same price, not sure about international shipping..
He can as well buy new P3A gimbal for $279 and modify with his spares to work as P3P gimbal :)
True.. but the top electronics housing has to be working. The external fan is hot glued to that board. I believe the cameras are actually the same in reality and that the top board of the gimbal is what controls the 4K functions..
Correct
I use metal retainer pins to secure the camera instead of the plastic ones supplied by DJI. The plastic ones are just too weak to provide the needed protection in crashes.
With either the metal or cable ties, do you still see the same level (or maybe more) of vibration dampening? Would seem like the metal stays would allow more than cable ties? Where did you find those metal ones?
Yes -- both are installed loosely though. Their only purpose is to prevent the gimbal from separating from the Phantom in a crash.
You can purchase them here.
intertronixlabel
