Phantom 3 pro gimbal?
Indonesia
While flex cable is the most common point of failure, if electronics doesn't power on, I'd first check the power.
Places on the board where specific voltages should be are marked with said voltage, ie "3V3" or "1V2" or "5V".
dji phantom 3 pro gimbal board is off, I tried to check the normal 12v voltage, for 3v 5v it doesn't exist ... please help sir, what components should I replace ... thanks for the help.
halo pak, saya ada masalah flashing board dji phantom 3 pro gimbal, ada kerusakan nand flash chip yang saya tanya ... saya pasang board phantom 3 pro gimbal, apakah berfungsi sebagai board phantom 3 advanced gimbal tanpa menggunakan flash nand chip ...
hello sir, I have a problem with the phantom 3 pro gimbal board, the damage is on the nand flash chip, if I modify the phantom 3 pro board so adv can I remove the chip and upload advanced firmware ...?
Please help.
can I remove the chip and upload the phantom 3 adv firmware ...?
Some people did that. Though none cared to prepare a detailed guide.
You need to desolder at least one zero ohm resistor and re-solder it in different orientation to route the video from Ambarella to the USB which connects to OFDM board. And you need to change the firmware. I can't remember much more, but this was discussed in public posts, so you should find at least a few more details if you search.
